how to configure ZABBIX 1.6 for SNMP devices?
  • ninad
    • Feb 2010
    I am intern in one company i deploy ZABBIX for our LAB but now i am not able to configure it for SNMP devices I am really ameture in zabbix and linux please elaborately explain me how to do this with auto discovery of all devices too
    also on other hand how to configure linux box for this SNMP configuration?
    despartly waiting for you people help
  • fege
    • Dec 2008
    • 34
    on a host you add an item and select as type snmp v1 or v2 or v3, and set the correct oid start with . (dot)
    have you change your snmpd.conf for your use?
    the community must be public
    • edgonz
      • Feb 2010
      • 9
      You can also assign an SNMP template on those devices as well. I'm assuming you're trying to monitor a switch or a router?
      You can download some templates here.
      I've found using templates easier than some other methods. It's a bit more work, since you may have to modify the XML, and you may have to find out the OIDs from net-snmp.
      If you're trying to monitor a network device, try the templates, and if you need help modifying the template I can try to assist you. I just modified the template for a Cisco 3750 48port switch to fit my needs, so I have that fresh in my head.
      • ninad
        • Feb 2010
        thanks
        but Now i am able to monitor Hp switches cisco routers
        my main problem is with all debian based linux servers here i made some changes in its snmpd.conf file by i am able to snmpwalk from my zabbix server to that debian host but after adding it in host it giving me error
        Get value from agent failed: Cannot connect to [10.1.125.249:161] [Connection
        can anyone help what I have to do?
        com2sec local localhost public
        com2sec localNet (ip of my zabbix) public
        group MyROSystem v1 local
        group MyROSystem v2c local
        group MyROSystem usm local
        group MyROGroup v1 localnet
        group MyROGroup v2c localnet
        group MyROGroup usm localnet
        group MyRWGroup v1 local
        group MyRWGroup v2c local
        group MyRWGroup usm local
        • ninad
          • Feb 2010
          getting an error as connection refused on web monitoring interface of zabbix
          • RafaelMoreno
            • Jul 2009
            • 58
            Originally posted by ninad
            thanks
            First of all,
            YOU DON'T NEED TO OPEN A PUBLIC COMMUNITY.
            You can change the template to fit your needs
            Now lets go to the trouble shooting
            First thing,
            Go to your machine and try to ping your Cisco Switch
            If it's pinging search your Cisco switch on Zabbix, go to the items and check all the boxes.
            Do a Mass update.
            Check the box that has SNMP Community
            put your community on it.
            give an ok
            Wait about 2 minutes to give your zabbix server a try to connect on the SNMP.
            If it does not work tell us again...
            Thanks,
            • ninad
              • Feb 2010
              thanks i did it now able to monitor it
              I want to monitor debian based dell servers but i dont want to use zabbix agent
              and the linux template that we have uses zabbix agent
              can some one guid me or give me source the template of linux which uses snmp
              currently using snmpv2 templete to monitor servers but it doesnt provide much info
