runts, input errors, CRC on cisco 2660
  • ghbage
    • May 2010
    • 10
    Hello all.
    I wish a help.
    How i can monitor the errors like (runts, input errors, CRC ) on Cisco switch 2960? or what is the items i have to watch?
    Excuse my English.
    Thank's
  • MrKen
    • Oct 2008
    • 652
    Hi ghbage,
    You can monitor this by snmp. You will need to have configured zabbix --with-net-snmp.
    Here are some OIDs for you to try:
    Runts 1.3.6.1.4.1.9.2.2.1.1.10
    Giants 1.3.6.1.4.1.9.2.2.1.1.11
    CRC 1.3.6.1.4.1.9.2.2.1.1.12
    Frames 1.3.6.1.4.1.9.2.2.1.1.13
    Overrun 1.3.6.1.4.1.9.2.2.1.1.14
    Ignored 1.3.6.1.4.1.9.2.2.1.1.15
    Collisions 1.3.6.1.4.1.9.2.2.1.1.25
    Follow this link to find out more about the above OIDs, and what MIBs you will need to install: http://tools.cisco.com/Support/SNMP/...itClicked=true
    And, just in case you need an snmp tutorial http://www.net-snmp.org/wiki/index.php/TUT:snmpwalk
    MrKen
    • ghbage
      • May 2010
      • 10
      Thanks MrKen for your for respond.
      What is the difference between the net-snmp and the default snmp template in Zabbix. it's what i activated in switch?
      T. a Lot
      • MrKen
        • Oct 2008
        • 652
        Net-snmp is what you need to configure zabbix with in order to use snmp. Check your zabbix_server.log for this:
        21074:20100506:144908 Starting zabbix_server. ZABBIX 1.6.6 (revision 7836).
        21074:20100506:144908 **** Enabled features ****
        21074:20100506:144908 SNMP monitoring: YES
        21074:20100506:144908 WEB monitoring: YES
        21074:20100506:144908 Jabber notifications: YES
        If you don't have that then you need to
        ./configure --enable-server --prefix=/usr/local/zabbix --with-mysql --with-net-snmp --with-jabber --with-libcurl
        The Templates are what you link to a host, to monitor that host.
        The default snmp template might be a good place for you to start, but it doesn't monitor runts, CRCs, etc.
        You might need to create your own template. Perhaps the SNMP Builder for Zabbix is worth trying, I think it can create a template for you (if you have the MIBs) http://www.zabbix.com/forum/showthread.php?t=15088
        There are some more templates here: http://www.zabbix.com/wiki/templates/start
        MrKen
        • ghbage
          • May 2010
          • 10
          Thank you again MrKen.
          I am going to follow all your various ideas, and post my feedback.
          • ghbage
            • May 2010
            • 10
            Hi everyone.
            This is what i received this morning after the configuration that i made last Friday :
            locIfInRunts Triggers (0) locIfInRunts 60 7 365 SNMPv2 agent Not supported
            Do someone knows what this means ?
            • MrKen
              • Oct 2008
              • 652
              It means that the Item is Not supported. That means that either the Item configuration is wrong, or you have not configured zabbix --with-net-snmp, or you have not enabled snmp on your device.
              Do you see this 'SNMP monitoring: YES' in the zabbix_server.log when you start the server?
              Can you also post details of the Item configuration (or a screenshot of Item config).
              MrKen
              • Murilex
                • Nov 2009
                • 124
                Once I had problems polling some of my switches/routers using SNMPv2. Try using SNMPv1 instead. This solved my problem.
                • ghbage
                  • May 2010
                  • 10
                  hi
                  this is what i have in my log message:
                  SNMP error [(noSuchName) There is no such variable name in this MIB.
                  • ghbage
                    • May 2010
                    • 10
                    For exemple, this is one of my screenshot:
                    • MrKen
                      • Oct 2008
                      • 652
                      Where?
                      Can you provide some details about the item config., and the OID that is causing the error.
                      • ghbage
                        • May 2010
                        • 10
                        Hi.
                        I think of having understood where my error came from.
                        For example: when we use the snmpwalk command, this one can displayed one or several values.
                        In my case, for the OID: collisions 1.3.6.1.4.1.9.2.2.1.1.25, it was necessary to add the extension .10101 for the interface G0 / 1 and so on.
                        I hope , I have been clear in my feedback...
                        PS: sorry MrKen, I have a problem when i tried to load my screenshot.
                        • ghbage
                          • May 2010
                          • 10
                          MrKen
                          Do you have an idea about how to monitor VPN connexion on Checkpoint?
                          thank's
                          • MrKen
                            • Oct 2008
                            • 652
                            Click on any of the OIDs to see a description.
                            Or this one:
                            • ghbage
                              • May 2010
                              • 10
                              #15
                              Thank's MrKen; you are the best!!
                              I used this one: http://www.oidview.com/mibs/2620/CHECKPOINT-MIB.html.
