sysmaps_link_triggers contains, as the name suggests, map link-trigger linkage.
deleting an item should delete the trigger, and deleting the trigger should remove it's reference from this table.
if you can compare trigger linkage for some older map with one for a fresh map, maybe you can spot some difference.
we wouldn't want you to run out of older maps, would leave use without playground
