I can't edit my map
  • patrice
    • May 2010
    I can't edit my map
    Hello everybody.
    I have a problem.
    When i want edit my map (add elements, links, ...) i can't see my map.
    If i add element, i can see my background image of my map but not element and link.
    Also, when i go to monitoring map menu i can see all my map with element, link, ...
    Sorry for my english, i'm very bad.
    i have this problem since two weeks.
    Thank you for your answers.
    Please help me.
  • richlv
    • Oct 2005
    • 3112
    zabbix version ?
    browser used ?
    any js errors reported by browser ?
    any errors logged in apache error log ?
    • patrice
      • May 2010
      zabbix version ?
      1.8.2
      browser used ?
      IE8 (and with Firefox it's the same problem)
      No js errors reported by browser
      No error logged in apache error log
      • richlv
        • Oct 2005
        • 3112
        i would suggest trying with 1.8.3 - map editing has been made much more robust in that version
        • dudink
          • Aug 2009
          • 20
          I have the same problem - suddenly no longer displayed when editing the background and the missing links. Grid hosts remained in place, but if they choose - they jump in the upper left corner of the screen. This happens in any browser - Internet Explorer, Mozilla Firefox, Google Chrome. Zabbix version 1.8.2, FreeBSD 7.2-RELEASE-p3. Export maps to xml correctly. I am shocked, what to do, after all cards have only one of the main functions of zabbix for me. Please help!
          • dudink
            • Aug 2009
            • 20
            Answered himself - everything was fine after I discovered the lack of disk space in /var/log - file "messages" has increased up to 8 GB!. After cleaning - everything worked!
            • richlv
              • Oct 2005
              • 3112
              you should have an item and trigger in zabbix to monitor free diskspace
              • Zaniwoop
                • Jan 2010
                • 232
                I had the same problem, but I know what caused it.
                I had a host with a link and a link indicator tied to a trigger. I had made a change to the host, and the specific trigger was no longer applied to that host.
                This obviously confused the system.
                I fixed the problem by deleting and recreating the link.
                • richlv
                  • Oct 2005
                  • 3112
                  this seems to work as expected in current svn head. can you still reproduce the problem with 1.8.3 ?
                  if yes, what exact steps should be taken ?
                  • Zaniwoop
                    • Jan 2010
                    • 232
                    Yes had this happen recently on 1.8.3
                    • richlv
                      • Oct 2005
                      • 3112
                      so this does not happen always, but just every now and then ?
                      and when this happens, there are no messages logged in apache error log ?
                      • Zaniwoop
                        • Jan 2010
                        • 232
                        it happens if I remove an item off a host and a link state is dependent on a a trigger of that item.
                        • richlv
                          • Oct 2005
                          • 3112
                          well, i just can't reproduce this. does it really happen with 1.8.3 ?
                          if yes, can you give _exact_ steps to break a map ?
                          • Zaniwoop
                            • Jan 2010
                            • 232
                            hmm....
                            I can only recreate it with maps created in pre-1.8.3
                            If I create a new map, I can't get it to happen
                            • richlv
                              • Oct 2005
                              • 3112
                              #15
                              interesting. if you check map options, do they match ?
                              would be great if you could compare previous map and new map in the database, although that would require looking at several tables...
