hello,
I have been trying to get log file monitoring to work for over a week now.
I have searched the forums as much as I could and read the online manual.
Here is what I have setup for the item:
type: zabbix agent(active)
key: log["/usr/local/jboss/server/default/log/server.log", "OutOfMemoryError","UTF-8", 1000]
Type of Information: Log
Latest data shows "Accessible only as an active check"
Checked the zabbix agent log file:
28076:20100922:082210.287 zabbix_agentd active check started [zabbix:10051]
I do not see any errors in the zabbix agent log.
I have confirmed in the zabbix_agentd.conf Hostname is exactly the same as the frontend GUI(including case sensitivity).
Disableactive is commented out.
Only one zabbix server and able to collect other data with zabbix agent ie. cpu stats and zabbix-sender items.
Running zabbix server: 1.8.3 and zabbix agent 1.8.3.
Please let me know what I have missed.
Thank you
Dat
Thank you
Dat
