Problem with graphs (and screens) on HP Blade VC
  • maciek
    • Oct 2010
    Hello
    I have strange problem with screens and graphs in Zabbix. I have few Blades Enclosures and I use Zabbix to monitor ports bandwidth on Virtual Connect (VC). Everything was ok, but last time I noticed that there is some problem.On different Enclosures and different ports there is no info about bandwidth (even if it's 0 bps) but there is string "no data". I tried to clone grapf and use the cloned one but it didn't help. I also prepared one new grapf for test but it didn't help too. It's strange because all items, triggers, graphs, etc. was prepared as a template and now on some enclosures everything is ok and on some there is "no data" info. Problem affects port that are conected and works and that are disconnected (in this case it should be bandwidth 0 bps like in others enclosures). Problem also affects random ports (but no more than one in single VC module), so it means that on one Virtual Connect all is ok, on the second is problem with port 8, on the third i problem with port X2, etc. It's affects different enclosures and VC modules. Anyone can give me any advice or help?
  • maciek
    • Oct 2010
    I noticed the problem affects also other equipment that we monitor using Zabbix - LAN switches, storage arrays, etc. So it's defenetly problem with Zabbix (I think). Or maybe MySQL database? Anyone has any idea? I'm using Zabbix 1.8.1 and on the screens there is no data from particular host or partially no data (example infor from half ports on LAN switch are ok and from the rest is no data).
