Looking for a way to monitor filesystem for "read only"
  • agentguerry
    • Jul 2009
    • 45
    Hi all,
    Does anyone have a clue on a way to use zabbix agents to monitor if a filesystem (linux) has slipped into "read-only" state?
    Thank you,
    L
  • richlv
    • Oct 2005
    • 3112
    in a really simple way you could add a userparameter like this :
    UserParameter=vfs.mount.status[*],mount | grep "on $$1 "
    then on the item you could use regexp() function to check for occurrence of "(.*ro.*)" or similar.
    that would store in the db full mountpoint line, so you might also want to rewrite it so that only 1/0 is returned depending on ro/rw status. on the other hand, storing full line might allow to monitor other aspects (atime, acl and whatever other flags you might be interested in)
    • MrKen
      • Oct 2008
      • 652
      I have experienced this exact problem where a mounted partition has for some reason become unmounted, then has remounted itself as 'read only'.
      For me the solution was to monitor the log file, searching for the word 'Remounting'. This was tested and works fine. Then added a trigger called 'File System changed to Read Only'.
      Item.
      Type: Zabbix Agent (active)
      Key: log[/var/log/messages,Remounting]
      Type of Information: log
      Trigger.
      {MyHost:log[/var/log/messages,Remounting].nodata(30)}#1
      * You will need to check your logs for an appropriate word or phrase, maybe Remounting is not right for your situation.
      MrKen
      • LenR
        • Sep 2009
        • 1011
        Are you having VMware disks going read only? We do occasionally and I don't think the Linux mount status changes, it acts like a hardware error. You could use touch to create a file then test if it's there, if not, it's bad.
