Web Scenario: Getting a cookie into a variable
  • luizzmizz
    • Nov 2010
    • 14
    Hi!
    I'm new to zabbix, and i'm trying to move my company monitorization from ME to zabbix.
    We have a web authentication system a little messy, and not easy to change (politics). Every authentication web scenario needs to get a sessionid cookie and use it on the next url. So... i've been testing and i don't get it:
    Is it possible to get the JSESSIONID cookie in a step into a variable {sid} and then use this variable into the next step like 'http://url-next-step?session={sid}???
    In case it is possible, i'd be so happy to leave Manage Engine behind...
    Thanks in advance
    luizz
  • luizzmizz
    • Nov 2010
    • 14
    Hi!
    Just for simplifying the question... i need to assign a value to {sessionid} macro in step n, and then use it into the post of step n+1...
    so... it would be {sessionid}=xxx, but how do i refer to a cookie? and if this is solvable... where should i assign the value? in the post box of step n? or in the url? :S:S
    hope it simplifies
    thanks!
    • richlv
      • Oct 2005
      • 3112
      that is not currently supported, unfortunately
      • luizzmizz
        • Nov 2010
        • 14
        sadly accepted...
        is there any prevision? on 1.9.0 beta?
        anyway, thanks a lot for your fast response!
        • richlv
          • Oct 2005
          • 3112
          as far as i know, no short term plans for such a feature currently
          • luizzmizz
            • Nov 2010
            • 14
            Just a last question...
            i cannot assign a cookie value into a {macro}, ok, but can i assign a static value into a {macro} within a step? I mean, just like on the Web Scenario form, but on a step.
            Thanks and promise, it's my last question :S
            • richlv
              • Oct 2005
              • 3112
              hmm, no. also, i don't see what would be the point - if it's static, it's static. if you want a different value in a different step, you can just use a different variable
              • luizzmizz
                • Nov 2010
                • 14
                It was just in case... on the other product we used, they told us we could not get cookies, and we could do it via a var=$sessionid on that step...
                the only intention for the last question was, in the remote case that it would be possible, if it was possible also to assign that value on that moment... but nevermind, i believe my battle is lost already :S...
                i'll keep track of this feature, zabbix seems so mature...
                keep the good work!
                • richlv
                  • Oct 2005
                  • 3112
                  heh, well, if it's really important, maybe it's worth contacting the company and seeing whether the feature can be implemented for you.
                  • luizzmizz
                    • Nov 2010
                    • 14
                    Well, that would be superb!
                    Do I contact via forum/Suggestions or another way?
                    thanks!!!
                    luizz.
                    • richlv
                      • Oct 2005
                      • 3112
                      well, i guess both contact form and emailing to [email protected] would be ok
                      • luizzmizz
                        • Nov 2010
                        • 14
                        hello, richlv,
                        as no one answered my question on "ZABBIX Suggestions and Feedback", i'm coming back to you to ask for any other way of contact... our company is moving it's monitoring system and now we're on a hurry for knowing if zabbix "can be".
                        luizz.
                        • richlv
                          • Oct 2005
                          • 3112
                          hmm. if you are asking about possible custom development, did you try contacting [email protected] ?
                          • luizzmizz
                            • Nov 2010
                            • 14
                            Webinject
                            Hi!
                            I've found webinject, which does what we need, with its "parseresponse" option, and giving the times for each url visited. Every scenario is a xml file and therefor it's perfect for importing/exporting .
                            We tested it on Nagios and it works perfectly. The only problem is we want Zabbix. Is there any way of integration of this script into zabbix?
                            Thanks in advance,
                            Luis.
                            • richlv
                              • Oct 2005
                              • 3112
                              #15
                              is it returning something on a commandline ?
                              if so, you should be able to use it as a userparameter
