Zabbix Proxy with or Node
  • spaww
    • May 2009
    • 178
    I need to mount a distributed monitoring.
    Does anyone have a tutorial on a basic set of zabbix proxy with or node?
    An acquaintance tried to configure a proxy and said that after getting it to work was necessary to register the item to be collected at the proxy and the central node? This is the operation expected?
    Adail Horst
    OCA/OCP - Oracle Application Server
    ZABBIX Certified Specialist
    http://www.spinola.net.br/blog (Blog sobre Zabbix e tecnologia)
  • richlv
    • Oct 2005
    • 3112
    go with proxies.
    no, to get item monitored, you only configure it on the zabbix server - proxy picks up that change in configuration after a while automatically
