DM vs Proxies - notification?
  • nonspecialist
    • Dec 2010
    I'm looking to replace an existing Nagios deployment of 3 main sites, each of which has its own monitor server. Communications between the 3 sites are not always reliable, so I need to have each site be able to generate its own notifications, but I also want centralised configuration because we know, from our experience with Nagios, that supporting multiple independent configurations for the infrastructure is a major waste of time.
    I know that this is not possible with the current capabilities of Zabbix -- you can either have central configuration, and use Proxies, or you can have independent notifications, and use Nodes, but you can't have a unified configuration managed centrally with nodes.
    Are there any plans to add either notification capabilities to Proxies, or permit centralised configuration (and dashboard) using DM Nodes? This would make Zabbix a serious contender in the Enterprise monitoring space against Hyperic, Zenoss and so on.
    I've considered using MySQL triggers and DB replication to try and add this into the 1.8.x, but I want to know if it's worth my time to do this, or whether I should just give up and go for a commercial monitoring system.
  • nonspecialist
    • Dec 2010
    Bump
    Does anyone have any insight to provide on this? I'd love to be able to use Zabbix, but if we have to manually replicate configuration changes to 3 sites, then distributed monitoring is going to be useless to us; and using a proxy in each site means that if our inter-site links are down, we could lose all alerting for a site!
    • pjunod
      • Mar 2011
      I do not yet know exactly how the notification works for distributed monitoring, but I do know you can configure any of the nodes from the master node. There are a bunch of settings specifically for replicating the configs, and the manual references where you can go in and select a slave node to pull up it's configuration on the master.
      Also:
      This describes switching between nodes on the master:
      http://www.zabbix.com/documentation/..._between_nodes
      This details the configuration replication from master to slave and from slave to master:
      http://www.zabbix.com/documentation/...ring/data_flow
