Hello
I've been testing jabbix 1.8 for the last few days.
I've tried if it's possible to use it as enterprise management system for ~500 network devices and ~2k servers.
And i am very disappointed.
1. Architecture - it's a fail. There is only one level of templates (even in simple cacti there are three levels). What are the effects ? some examples:
a) i want to add 5 cisco routers (for example 7603): i need to create five different teplates for each router, in each template i need to add Items, in each item i need to type snmp OID, than i have to name each Item differently (because each interface on each router have different names!). All of this must be done manually. Even in cacti this is automated (cacti grabs snmp oids and propose interfaces traffic which could be graphed).
b) what if i have 100 identical cisco switches and i want to change color of incoming traffic from red to blue ? I need to manually change all 100 templates, and all items in each templates !
c) what if i have 100 identical cisco switches and i have changed snmp password on them ? I need to manually change all 100 templates and all items in each templates ! (i could use mass update but still it's a great work to do).
d) what if i want to display interface statistics of my routers in Mbit/s not int MB/s ? I can not.
e) what if i want to change legend on the graph ? i can not. I have to create other Item and add it to the graph.
f) what if i want to change name of Item (displayed on the graph) ? I can not - i have to create new Item.
g) i've created one item in my new template. I want to add 100 similar items (interface traffic for another 100 interfaces) - i can not. There is no clone options - i have to add it manually typing all 100 Items with all parameters like timers, units, history...
h) cisco templates from: http://www.zabbix.com/wiki/templates/start - none of them works (no error durring import, no errors in logs but the template does not appear after import). Existing templates for cisco: 87x, 2960, old pix 515/525 - it's definitely not enterprise gear.
Of course i found some other bugs, but it's not the issue here.
The summary for zabbix is: it's not for enterprise, and it's good only for monitoring PC stations using zabbix agent - definitely not for network gear, and other SNMP monitored gear. Moreover zabbix archtecture is not flexible and is much worse then other opensource available on the market.
I really appreciate your work, i know it's very difficult to spare your free time to build such opensource. But let's face a truth. Am i wrong ?
Best regards,
Michal
Best regards,
Michal
