change life of trends and history in web monitoring
  • neoyagami
    • Jan 2009
    • 13
    i need to change the life of trend and history in web monitoring.
    in the manual its says the history live 30 and trends 90 days
    but i need that data to live within a year.
    there is a way to do that?
  • marcel
    • Oct 2010
    • 112
    in each item configuration
    Zabbix Certified Specialist for Large Environments since 12/2010
    • atran
      • May 2008
      sorry, maybe its me but i can't find the items for those web monitoring steps!?
      btw. could this be done globally?
      • untergeek
        • Jun 2009
        • 512
        Yeah. The recent UI changes do not show the actual items in the host configuration like they used to. It would be nice to be able to do this without having to resort to editing the DB or using the API.
        • atran
          • May 2008
          Availability reports for web monitoring is limited to 3 month because of the maximum trend histroy of 90 days. This should be configurable...
          hope someone could help.
          • atran
            • May 2008
            how can i change this in mysql?
            • satchelp
              • Jul 2008
              • 13
              I agree, please bring back the ability to alter the individual web monitoring items. What benefit does this change have other than removing item clutter for the zabbix server? No reason to take away configurable parameters that many of us use.
              To fix this via mysql I did the following:
              UPDATE `zabbix`.`items` set trends = 365 where hostid = "id.of.your.zabbix.server" and type = 9; It looked to me like the only items that had type of 9 were the web monitoring stuff. Maybe if I changed the type to 0 they'd show up in the GUI. I haven't tested that yet.
              You can find the hostid of your zabbix server most likely by just doing a SELECT * FROM `zabbix`.`hosts` and finding the hostid that matches your zabbix server.
              Yes of course, there are more efficient ways to do this, but I'm not a mysql person and this is what worked for me.
              • atran
                • May 2008
                satchelp,
                thank you, that helped a lot.
                • bbrendon
                  • Sep 2005
                  • 873
                  Its been a long time and this thread appears to be valid for zabbix 2.2.
                  update items set trends=365,history=30 where type=9
                  Documentation states:
                  Web monitoring items are added with a 30 day history and a 90 day trend retention period.
                  Unofficial Zabbix Expert
                  Blog, Corporate Site
