Get users connected to specific application
  • fosh
    • Mar 2011
    Hello all,
    I am new here. I was install zabbix a few days ago and use it to monitor 5 servers. I found that zabbix is very great tool to monitor our servers.
    Now I have question. We have an application which listen on several ports. I want zabbix can tell me how much user connected to this application based on TCP state Established on ports?
    Or is there any way to do this ?
    Thank you
    Fosh
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I would create a user parameter, which would parse output of netstat (make sure option -n is used) and provide you with the requested stats.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • fosh
      • Mar 2011
      How do I create it? using script in server and send output to specific file?
      • Rudd
        • Mar 2011
        • 69
        In zabbix_agentd.conf
        UserParameter=myapp.con,netstat -n | grep 10050 | grep -c [:E:]STABLISHED
        In the template/host create an item with key "myapp.con"
