is http simple check a real http check ?
  • ghoz
    • May 2011
    • 204
    Hi all
    I'm wondering if the simple check htttp,<port> is realy an http check or just a 'port open' check...
    Out of curiosity I tested using another open port , the check keeps returning 'http is UP' , the only problem is that the tested port is a TSE port
    I guess I have to use a web scenario in order to realy check the web server, but if this is the case, what other simple checks are not realy services check ?
    do they realy the service or just check for open port ? I have to say it's a bit disapointing
    How do you guys test that a service is realy anwering and not just stuck there ? External checks with retrofitted nagios / whatever checks ?
    Thanks in advance
  • wikisb
    • May 2011
    • 64
    Hi Ghoz!!
    i was wondering the same thing a couple of weeks ago, i suppose you solved this issue. in case you didn't have a look at this:
