Host status
  • mary nancy
    • Jul 2005
    • 125
    Host status
    Hi
    I am using beta6 version. Can somebody guide me how to monitor a the status of the host. Eg:- in beta2 we had a parameter called "STATUS" to monitor. In beta6 this parameter is not supported.
    Please could someone help me in finding this parameter.
    Thanking you
  • elkor
    • Jul 2005
    • 299
    hey mary.
    I could be wrong here, but I do believe that status is calculated simply from server->agent (or in the case of active checks server<-agent) communication.
    no separate key is necessary.
    • bbrendon
      • Sep 2005
      • 873
      Originally posted by elkor
      hey mary.
      I'm pretty sure status is useless if you're using an active only agent that can not be reached by the zabbix server. For agents that are not reachable by zabbix, you know if they are down by using nodata() on an item.
      Unofficial Zabbix Expert
      Blog, Corporate Site
