Zabbix DB Backup Leads to Ping Failures?
  • mpureka
    • Apr 2011
    • 28
    I've been using a simple MySQLDump command to back up the Zabbix database, and this seems to be working well enough, except when the backup completes, Zabbix throws a "Ping Failed" event for every single Host in my configuration.
    What is the appropriate way to prevent this from happening?
  • f.koch
    • Feb 2010
    • 85
    hi,
    mysqldump locks the tables while dumping, you need to add --single-transaction.
    rgds flo
    • mpureka
      • Apr 2011
      • 28
      Originally posted by f.koch
      hi,
      rgds flo
      Well, that sounds easy! I'll modify my script accordingly and see how it goes.
