CPU Levels
  • Tractorboy
    • Oct 2010
    • 98
    CPU Levels
    I have a question on the ootb cpu metrics.
    What is it doing.
    The reason that I ask is that I have numerous servers with this metric and on one specifically the graph has hit 1200%. It only has 4 cores, so even if it added 100% per core then I'd expect 400% tops??
    Also have other servers that have many more cores, and there cpu levels seem about correct (comparing with taskmgr).
    I have used % and custom multiplier of 100 to store %age values if that make a difference. (This has been changed at the template level)
  • Tractorboy
    • Oct 2010
    • 98
    Wrong metric
    Seems like the ootb build uses the wrong metrics. hus shows misleading information.
    Found the correct metric and all looks much better.
