What is the best method to move (upgrade) from Zabbix 1.4 to 1.8 ?
I tried the 2nd option and it sort of worked, the hosts all lost their Templates though which is no good
. Also the web tests (web.test) produced XML errors when trying to import.
Also - are there any gotchas when upgrading - namely do certain item checks etc break ?
- Upgrade 1.4 to 1.6 and then to 1.8 ?
- export all hosts from 1.4 and import into 1.8
. Also the web tests (web.test) produced XML errors when trying to import.Also - are there any gotchas when upgrading - namely do certain item checks etc break ?
