I am trying to compile zabbix agent 1.8.4 - 1.8.7 on a QNAP TS-119P+ NAS system, which is powered by a Marvell ARM CPU. Unfortunately, it just aborts with following error message:
Haven't tried this on a x86 based NAS yet, but does anyone have a clue?
[/share/HDA_DATA/compile/zabbix-1.8.4] # ./configure --enable-agent --prefix=/opt/zabbix
./configure: line 14052: syntax error near unexpected token `('
./configure: line 14052: ` for ac_var in `(set) 2>&1 | sed -n 's/^\([a-zA-Z_][a-zA-Z0-9_]*\)=.*/\1/p'`; do'
Using built-in specs. Target: arm-none-linux-gnueabi Configured with: ../gcc-4.2/configure --build=i386-pc-linux-gnu --host=arm-none-linux-gnueabi --target=arm-none-linux-gnueabi --prefix=/opt --disable-nls --disable-static --with-as=/home/slug/optware/cs08q1armel/toolchain/arm-2008q1/bin/arm-none-linux-gnueabi-as --with-ld=/home/slug/optware/cs08q1armel/toolchain/arm-2008q1/bin/arm-none-linux-gnueabi-ld --enable-languages=c,c++ --disable-multilib --enable-threads --disable-libmudflap --disable-libssp --disable-libgomp --disable-libstdcxx-pch --enable-shared --enable-symvers=gnu --enable-__cxa_atexit Thread model: posix gcc version 4.2.3
