Actions on master node with events from Child node
  • sdebot
    • Sep 2011
    Hi @Forum,
    I would like to know if it is possible to create a working action on the master node from events of the child node. It is likely by design that is does not work as the child node is a standalone Zabbix server.
    Also the events coming from the child node are acknowledge automatically on the master node is that default behavior.
    Regards Stephan,
