I got the Zabbix version Pre-1.9.7.x (alpha) snapshot installed following the installation instructions here:
http://www.zabbix.com/documentation/...lation/install
I got everything installed successfully along with the web interface. However when I log into the web interface ( the Zabbix front end), on the dashboard page it show 'no' in the column for Zabbix server is running.
I had run the command: ./zabbix_server
under the directory (/usr/local/sbin/zabbix_server) to start the zabbix server ( as part of the installation instructions), so I thought that should have started it.
But I am not sure why it is showing up as not started in the Zabbix front end console. Any ideas or hints?
