SNMP STRING to integer-numeric conversion problem
  • PieterB
    • Jul 2010
    • 25
    I started creating an SNMP template for IBM BladeCenter H chassis
    (shared as soon as ready)
    Some values are returned as string instead of integer.
    Isn't the conversion automatic using numeric (float) ???
    For example
    "21.50 Centigrade"
    "473W"
    or "+5.25 Volts"
    I get no results when I use numric (float) or numeric (integer)
    I want to convert these to integers (numeric) in zabbix.
  • jwestarb
    • Feb 2012
    I have the same problem.
    I would like to conveter the "Centigrade 21:50" to "21:50" to store in Zabbix
    Is it possible?
    • netmon
      • Feb 2012
      • 30
      Same here, I also need to convert a STRING to INTEGER.
      Is there no possibility to do that?! Really?!
