Sheeva Plug as a Zabbix Proxy
  • nabberuk
    • May 2010
    • 82
    I'm looking into using the Sheeva Plug (found here) for running as a Zabbix Proxy. There won't be many items i'm fairly certain it will handle it.
    My question is which os? I'd like to use the onboard NAND (512MB) to boot from, what's the best os (footprint wise) and does anyone know the size of the zabbix proxy binaries?
    Thanks,
    Nathan
  • richlv
    • Oct 2005
    • 3112
    whichever os you know best
    binary size might vary from platform, features compiled in and other factors, but the one i have here is ~ 1mb.
    also keep in mind that you will need local db (probably best to use sqlite in this case), which will also take up some additional space
    • nabberuk
      • May 2010
      • 82
      Hi thanks for your reply.
      I've decided to wait till the raspberry pi's are available. There currently testing and if all goes well they'll start producing them in the new year.
      • Jason
        • Nov 2007
        • 431
        They're now currently available and I'm going to be looking at them as well...
        I'm hoping the general purpose IO on them will be useful for sensors
        • nabberuk
          • May 2010
          • 82
          I didnt manage to get one. hope someone else on here managed to get one and reports back on how good it is as a proxy etc.
