Monitoring a switch ?!?! :(
  • Markus_90
    • Feb 2012
    Hello everybody
    I have problems with zabbix & monitoring a switch.
    I am not a specialist so i need information for a beginner ;-)
    For a project for school I have to monitor a Cisco Catalyst 3500 XL switch. I have read a lot of in the internet but nothing could help me
    I want to do easy things like a poll ore monitor the CPU free capacity.
    My problem is, I dont know how does it works. I have read that I need a "OID" and MID Tables.
    The first Problem is how does I get this fucking OID????
    Than I have to know how I import the MID tables, that Zabbix could interpret the output from the OID.
    Could you help me ? Do you know what I mean? :-D And sorry for my bad English
    Greetings from germany
  • JBo
    • Jan 2011
    • 310
    Have you read SNMP part in Zabbix documentation ?
    You should become familiar with snmp command line tools, specially snmpwalk and snmpget in order to find relevant OIDs.
    Also, Zabbix comes with a few SNMP host templates.
    You can check Template_SNMPv2_Device to see how a SNMP item is configured.
    Regards,
    JBo
    • eskytthe
      • May 2011
      • 363
      Sorry but if you only need to do monitoring of one device, zabbix may be a bit to big to start with in my opinion.
      Maybe take a look at some small tools like:
      But please return to zabbix when you need more monitoring
      /Erik
