I'm new to this so bare with me any help would be great.
I've go into the web interface and added a host.
I've downloaded the source 1.8 and done the following on the client.
./configure --enable-agent
make install
added the server into the zabbix_agentd.conf
added the name as per what i made the host
but i can't for the life of me get the zabbix agent to talk to the server.
the /tmp/zabbix_agentd.log says its started OK but there is no IP address listed, googling showed others had IP's.
what kind of troubleshooting is available?
really struggling with this it seems simple but i can't seem to get it to work.
thank you.
make install
thank you.
