Hi everyone,
I write you because I´m having troubles with my windows 2008 R2 Standard server. I can´t monitor the system.cpu.util[,,avg5] on this server. My zabbix says that is not supported, however I can monitor other things in that server, for example host uptime, free memory, etc.
I'm using the following versions:
Zabbix Server and Agents: 1.8.11
Client: Windows Server 2008 R2 Standard 64 Bits.
Additionally, I have another Windows Server 2008 R2 Standard 64 Bits monitored with zabbix and everything is ok, I can monitor the proccessor with system.cpu.util[,,avg5].
¿Any ideas?
I really apreciate your help friends!!!!!
¿Any ideas?
