I've previously (In Zabbix 1.8.5 I believe) configured Templates that can have triggers that use items in the template and items on a static host.
(For example, we have a SVN replica lag check, so we have a Template for each SVN replica that checks the current SVN version and then compares that with the master).
Since we've upgraded to 1.8.13 however the old triggers are still there, but I can't add any new similar triggers. Even when I go into one of the old triggers and push save it complains with:
"Incorrect trigger expression. Trigger expression elements cannot not belong to a template and a host simultaneously."
Is this intentional so the only way to do it is to manually setup every trigger between each slave and the master or have I just missed something?
Raise a feature request and see what feedback you get.
