Zabbix Migration from 1.8 to 2.0
  • nottl
    • Jun 2012
    Dear Forum Users,
    we want to migrate all configuration data (hosts, templates, ...) to a new zabbix 2.0 installation.
    Is there a howto or something else?
    What data can be migrated?
    Thanks in advance
  • smitty
    • Mar 2011
    • 13
    I'm also interested in this... I do not need to keep performance history, if that makes things easier/faster.
    • HullZabbix
      • Feb 2011
      • 104
      http://www.zabbix.com/documentation/...lation/upgrade
      • nottl
        • Jun 2012
        Sorry Dude, we want a complete host transfer.
        We dont want to update the old 1.8 box to 2.0.
        So, who knows some best practices, migrating the settings, templates, ... to a new zabbix server.
        • HullZabbix
          • Feb 2011
          • 104
          As far as I'm aware your only option is a database backup and restore.
          I've just completed the process - we needed to move zabbix to a new machine.
          Built a fresh zabbix 2.0 server, then used mysql dump to backup and then restore to the new server.
          What DB are you using?
          • mike@vtg
            • Jan 2011
            • 28
            I had database problems in 1.8 of my own making and was unable to get a stable MySQL dump of the database to upgrade it to 2.0. As a result I chose a fresh installation of 2.0 and tried to export and import most things including hosts, templates, etc.
            It was a very painful process due to some errors that the import procedure did not like, and I highly recommend upgrading/working with the existing database if possible rather than having to spend the time I did with failed imports and manual host/template recreation.
