Trouble with actions
  • mherrman
    • Jul 2012
    Hi *,
    after setting up my zabbix-server, i`ve got some problems with actions.
    I`ve defined an action like this:
    Maintenance status not in "maintenance"
    Host template = "Template_SLA-Mittel"
    Trigger value = "PROBLEM"
    Trigger severity >= "High"
    But this doesn`t work, although the host is checked using the template called "Template_SLA-Mittel", where also the triggers are defined. If a host using this template is experiencing a problem, the action doesn`t send an e-mail like it`s configured.
    Can anyone tell me why? Is "Get-a-warning-from-a-action-using-templates" unsupported, deprecated or a known bug?
    Thanks in advance,
    Maxi
