SSH test from zabbix_agent
  • brandy
    • May 2006
    • 20
    I have disabled the trigger for the zabbix.agent ssh test, because we get the following error each time the agent test the ssh connection:
    Read from socket failed: Connection reset by peer
    But the agent still checks the ssh port. How can i deactivate this?
    greets
    thomas
  • brandy
    • May 2006
    • 20
    Alexei, maybe you can answer to this question?
    THX
    greetings brandy
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Disable Item, not trigger. By the way, where do you see the warning message? I assume it is in SSHD log file.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • brandy
        • May 2006
        • 20
        yes, i see this messages in the system log of our machine. it comes from the ssh daemon. it seems, that the agent closes the connection to fast.
        thanks for your help!
        greetings brandy
