I would like to use active check to supervise windows services
While "active" is working fine, "active check" does not work for the same item
definition (service[snmp])
I don't know if I am using active check correctly or if it is a bug
any help (or documentation on active check is welcome)
I am using beta 9
Regards
I am using beta 9
Regards
