Greetings,
I am trying to set up network discovery for an IP range as indicated in http://www.zabbix.com/documentation/...discovery/rule.
However, I am unable to get the conditions listed in "Step 2 - Defining an action for adding the discovered Linux servers to the respective group/template." The only ones I see are indicated in the attached screenshot. How can I see/add the conditions in step 2? I am using Zabbix 2.0.2.
Thanks in advance!!
Thanks in advance!!
