Macros in {TRIGGER.COMMENT} / {TRIGGER.DESCRIPTION}
  • Filter
    Hi there,
    I am wondering whether macros used in trigger comments/trigger descriptions (2.0.4) should resolve.
    I am running Zabbix 2.0.3 and I cannot get *any* macro to resolve in {TRIGGER.COMMENT}.
    Thank you very much
    I hate to be that guy, but
    *bump*
      Sorry - I am not quite sure what you are asking about - but according to
      http://www.zabbix.com/documentation/...ed_by_location
      you can only use the macro in "Notifications and commands" (Actions).
      Works fine for me in 2.0.3rc2.
        I am indeed using {TRIGGER.COMMENT} in "Notifications and commands" (Actions) which works as expected.
        The issue I am facing is that my actual trigger comment contains macros and those do not resolve.
        I have attached a screenshot of an example trigger comment that should explain what I want to do.
          Ok, now I understand. I do not think this is a supported feature - your user micro will not be resolved.
          BR
          Erik
            For reference here is a list of the different macros supported by location:
            https://www.zabbix.com/documentation...ed_by_location
            For alerts just look at the first column of checkboxes.
              Forgot to follow up on this.
              https://support.zabbix.com/browse/ZBXNEXT-1466
              Announcement
              No announcement yet.
