I am loosing hope
  • kqfp31
    • Apr 2012
    • 48
    #16
    Originally posted by Shad0w
    grep -i zabbix /etc/passwd
    which shell do you have?! /bin/false ??
    when yes, you must set it to /bin/bash.. otherwise zabbix can“t login
    Help, how to check this shell? Or how to change this?
    • Colttt
      • Mar 2009
      • 878
      #17
      edit the /etc/passwd
      change the shell for zabbix-user..
      from /bin/false to /bin/bash
      Debian-User
      Sorry for my bad english
      • kqfp31
        • Apr 2012
        • 48
        #18
        Ok, i done this, but now I have this information:
        What is wrong with this system? :\
        • Colttt
          • Mar 2009
          • 878
          #19
          nothing.. its all right
          its case-sensitive!
          try:
          sudo su - zabbix
          Debian-User
          • kqfp31
            • Apr 2012
            • 48
            #20
            its case-sensitive!
            try:
            sudo su - zabbix
            Oh, man I don't have permissions to this location:
            zabbix@ht-50814ffc17b2c:~$ ls /etc/zabbix/alert.d/
            ls: cannot open directory /etc/zabbix/alert.d/: Permission denied
            But why? I done chmod 755. Like it's writing in every manual.
            What I shoul do to give Zabbix user this permissions?
            • kqfp31
              • Apr 2012
              • 48
              #21
              Ok, I give access to this file for Zabbix user but still I can't send notifications from Zabbix:
              zabbix@ht-50814ffc17b2c:/etc/zabbix/alert.d$ ls
              You gmail.sh zabbix_sendmail_test.conf
              cli_sms_clickatell.php smstrade.php zext_msmtp.sh
              gmail.conf zabbix_sendmail.conf
              • Colttt
                • Mar 2009
                • 878
                #22
                ok.. can you run this script manually? work it?
                please post you script and the output from
                ls -l /etc/zabbix/alert.d/
                Debian-User
                • kqfp31
                  • Apr 2012
                  • 48
                  #23
                  Sorry, that I made 3 post, but I can't paste everything in one post.
                  zabbix@ht-50814ffc17b2c:/etc/zabbix/alert.d$ ls -l /etc/zabbix/alert.d/
                  total 28
                  -rw-r--r-- 1 zabbix zabbix 0 Nov 12 16:13 You
                  -rwxr-xr-x 1 zabbix zabbix 4004 Nov 7 18:18 cli_sms_clickatell.php
                  -rwxr-xr-x 1 zabbix zabbix 228 Oct 26 16:38 gmail.conf
                  -rwxr-xr-x 1 zabbix zabbix 2662 Oct 26 18:11 gmail.sh
                  -rwxr-xr-x 1 zabbix zabbix 1744 Nov 12 14:51 smstrade.php
                  -rwxr-xr-x 1 zabbix zabbix 388 Nov 20 14:59 zabbix_sendmail.conf
                  -rwxr-xr-x 1 zabbix zabbix 397 Nov 20 14:53 zabbix_sendmail_test.conf
                  -rwxr-xr-x 1 zabbix zabbix 219 Nov 20 15:08 zext_msmtp.sh
                  And results of runing scrpits are below. This is crazy. Any of scripts is working. Only fifth script don't give errors, but any sms is going on my phone. Alsko, in smstrade.eu I have information that no smsm was send. I don't understant this ;/
                  zabbix@ht-50814ffc17b2c:/etc/zabbix/alert.d$ ./gmail.sh
                  ./gmail.sh: line 1: $'\E[?1049h\E[?1h\E=\E[1': command not found
                  ./gmail.sh: line 1: $'24r\E[?12': command not found
                  ./gmail.sh: line 1: $'25h\E[?12l\E[?25h\E[27m\E[m\E[H\E[2J\E[?25l\E[24': command not found
                  ./gmail.sh: line 1: 1H/etc/msmtprc: No such file or directory
                  ./gmail.sh: line 1: $'1Hdefaults\r': command not found
                  ./gmail.sh: line 2: tls: command not found
                  ./gmail.sh: line 3: tls_starttls: command not found
                  ./gmail.sh: line 4: tls_trust_file: command not found
                  ./gmail.sh: line 5: $'\r': command not found
                  ./gmail.sh: line 6: account: command not found
                  not found: 3(NXDOMAIN)
                  ./gmail.sh: line 8: port: command not found
                  ./gmail.sh: line 9: auth: command not found
                  ./gmail.sh: line 10: user: command not found
                  ./gmail.sh: line 11: password: command not found
                  ./gmail.sh: line 13: logfile: command not found
                  ./gmail.sh: line 14: unexpected EOF while looking for matching `''
                  ./gmail.sh: line 23: syntax error: unexpected end of file
                  Second:
                  zabbix@ht-50814ffc17b2c:/etc/zabbix/alert.d$ ./zabbix_sendmail_test.conf
                  Nov 20 15:35:30 ht-50814ffc17b2c sendEmail[19268]: ERROR => Can't use improperly formatted email address: @gmail.com
                  Third:
                  Nov 20 15:35:55 ht-50814ffc17b2c sendEmail[19270]: ERROR => Can't use improperly formatted email address: @gmail.com
                  • kqfp31
                    • Apr 2012
                    • 48
                    #24
                    continue...
                    Fourth:
                    zabbix@ht-50814ffc17b2c:/etc/zabbix/alert.d$ ./cli_sms_clickatell.php +48793383812 "qwr" "oqwn"
                    PHP Warning: file_put_contents(/var/log/zabbix-server/sms/sms_alert_clickatell_20121120153632): failed to open stream: No such file or directory in /etc/zabbix/alert.d/cli_sms_clickatell.php on line 53
                    PHP Warning: file_put_contents(/var/log/zabbix-server/sms/sms_alert_clickatell_answer_20121120153633): failed to open stream: No such file or directory in /etc/zabbix/alert.d/cli_sms_clickatell.php on line 126
                    Fifth:
                    zabbix@ht-50814ffc17b2c:/etc/zabbix/alert.d$ ./smstrade.php +48793383812 "qw" "adsdfsf"
                    • kqfp31
                      • Apr 2012
                      • 48
                      #25
                      Sixth:
                      zabbix@ht-50814ffc17b2c:/etc/zabbix/alert.d$ ./zext_msmtp.sh
                      ./zext_msmtp.sh: line 1: account: command not found
                      ./zext_msmtp.sh: line 2: tls: command not found
                      ./zext_msmtp.sh: line 3: tls_starttls: command not found
                      ./zext_msmtp.sh: line 4: tls_trust_file: command not found
                      smtp.gmail.com is an alias for gmail-smtp-msa.l.google.com.
                      gmail-smtp-msa.l.google.com has address 173.194.70.108
                      gmail-smtp-msa.l.google.com has address 173.194.70.109
                      gmail-smtp-msa.l.google.com has IPv6 address 2a00:1450:4001:c02::6c
                      ./zext_msmtp.sh: line 6: port: command not found
                      ./zext_msmtp.sh: line 7: auth: command not found
                      ./zext_msmtp.sh: line 8: user: command not found
                      ./zext_msmtp.sh: line 9: password: command not found
                      ./zext_msmtp.sh: line 11: logfile: command not found
                      Seventh:
                      zabbix@ht-50814ffc17b2c:/etc/zabbix/alert.d$ ./zabbix_sendmail.conf
                      Nov 20 15:39:16 ht-50814ffc17b2c sendEmail[19322]: ERROR => Can't use improperly formatted email address: @gmail.com
                      • Colttt
                        • Mar 2009
                        • 878
                        #26
                        ok that works.. how do you configure this action or the notificatioN?! (Screenshot)
                        Debian-User
                        • kqfp31
                          • Apr 2012
                          • 48
                          #27
                          I have something like this:
                          • Colttt
                            • Mar 2009
                            • 878
                            #28
                            ok, but i want to see the configuration of media-types
                            sorry my bad
                            Debian-User
                            • kqfp31
                              • Apr 2012
                              • 48
                              #29
                              Of course. Please
                              This is everything that I have:
                              • Colttt
                                • Mar 2009
                                • 878
                                #30
                                hmmm.. it looks all good..
                                is there an logfile in you scripts? when no try in the end of you script following:
                                echo "Zabbix testmail script works" >> /tmp/zabbix_mail
                                after this do an alert and show if this file create..
                                Debian-User
