root@ht-50814ffc17b2c:~# echo "Zabbix testmail script works" >> /tmp/zabbix_mailroot@ht-50814ffc17b2c:~# ls tmp/zabbix_mail ls: cannot access tmp/zabbix_mail: No such file or directory
root@ht-50814ffc17b2c:~# vi tmp/zabbix_mail
root@ht-50814ffc17b2c:~# echo "zext_msmtp.sh" >> /tmp/zabbix_mail root@ht-50814ffc17b2c:~# vi tmp/zabbix_mail
hmmm.. it looks all good..
is there an logfile in you scripts? when no try in the end of you script following:
after this do an alert and show if this file create..
please read properly!
in the end of you script you must add this:
after this run you script from the zabbix-frontend by a trigger or somthing like that.. and when you run it successfully you can chek if the file /tmp/zabbix_mail exist this script runs, and when you has no mail recived you has an error in you script!
Ok, i done this with every script and I only have something like this:
zext_msmtp.sh
In log I have information that script works, but i don't get any information.
