Delaying notifications for specific time period.
  • ncurry
    • Oct 2011
    Is there a way to delay notifications until a trigger has been experienced for a specified amount of time? I have a few network connections that are monitored and every once in a while they disconnect and then are quickly reconnected. During which time the zabbix agent sees the disconnected state and then sends out a notification. Shortly after an OK email is sent out. Would it be possible to setup either the trigger or the notification to check for a disconnected state that lasts longer than say 2 minutes or spans so many check intervals? Thanks in advance.
    Nate
  • LenR
    • Sep 2009
    • 1010
    Action escalations - http://www.zabbix.com/documentation/...on/escalations
    See example 2
    • ncurry
      • Oct 2011
      Would that still send a notification if the issue resolves itself within the time period?
      • LenR
        • Sep 2009
        • 1010
        In the actions section of the doc, it says "If enabled, Zabbix will send a recovery message after the original problem is resolved. The messages will be sent only to those who received any message regarding this problem before.", so I don't think you get a recovery unless a "problem" message has been sent.
        • ncurry
          • Oct 2011
          What I meant was that in setting the setting to say 120 seconds will a message only be delayed for 2 minutes or if the trigger is resolved in that time period will any notification be sent at all? Thanks for responding.
          • LenR
            • Sep 2009
            • 1010
            If it resolves in the 120, I'm pretty sure no messages are sent, either failed or resolved. I think that is what you want :-)
            • ncurry
              • Oct 2011
              That is exactly what I am looking for. I'll set it up and test it out. Thanks again for your help.
              • mkash28
                • Oct 2015
                • 13
                did that work the way you wanted?
                wondering what settings you used to get what you wanted (delayed alerts)? I need something similar done for false alerts. appreciate if you can share your settings.
