Notification via digital output
  • Zodde
    • Dec 2012
    We would like to send the notification as a summary signal via electric 24 V signal (via PCI express digital I/O-card). Email or SMS is not useful for our needs.
    Does anyone know if there exists a plugin or an example of how to do this ?
    Is it even possible ?
  • eskytthe
    • May 2011
    • 363
    One way is to run a local or remote command/script in your action, witch control your digital I/O-card.
    Something like this:
    You can also create your own media types - which execute your command/script, e.g:
    Br
    Erik
