Agent- send data only if something goes wrong
  • vienna
    • Mar 2013
    Hi all,
    I got the following construct running:
    Zabbix Server ---> Agents active
    The agents are sending back data in the configured intervall. Is it possible, to let them only send data to the zabbix server if they match a trigger? (Do the agents know about their triggers?)
    And if this is possible, can we also send the performance data for graphs after a custom intervall bundled, e.g. every 10 minutes, or is this completly generated from zabbix?
    BR,
    vienna
  • heaje
    • Sep 2009
    • 325
    Only the Zabbix server knows about triggers. The agents know nothing about them.
    • albort
      • Feb 2013
      Naja, the Agents can not help you!
