When updating hostname, zabbix complains that host already exists.
  • joshuamcdo
    • Oct 2026
    When updating hostname, zabbix complains that host already exists. However, this is simply not true on any level.. I have searched through and through and cannot find the host name that it keeps saying already exists. The old and new host names are nothing alike. I am pretty confused at this point as to why zabbix keeps making this complaint.
    Just curious if any of the gurus have seen this before.. I am about to start messing with the database, which never ends well at all.
    Thanks,
    J
  • joshuamcdo
    I dumped the database, and the host name is in there.
    I don't understand *QL talk, but I do see the hostname is in there. It almost appears to be associated with an old group name. A name that I renamed to something else, so the group doesn't actually exist anymore... I am going to try re-creating the group it's self and see what happens.
    J
    • joshuamcdo
      Solved.. Sorta...
      So after utilizing one of my co-workers mad db skills.. We learned that the host does exist but it's VISIBLE name is different than the host name. So when doing a search for the host it skips the hostname and only uses the visible name. This almost seems like a bug to me.
      J
      • Heilig
        • Mar 2013
        • 366
        It's not a bug, please read man page about global search.
        • joshuamcdo
          Really? I wouldn't expect any software package to behave this way.
          So just to make sure I understand what the man page is stating...
          <snip>
          7.1 Entities searched
          It is possible to search for these entities and their properties:
          * Hosts
          * Visible name (or host name if visible name is not defined)
          </snip>
          If that's accurate, that there is no away around this issue. That is totally unexpected behavior, and I would hope that in the future one would have say a check box to search just the real hostname instead of the visible.
          J
          • Heilig
            • Mar 2013
            • 366
            You can use advice or be a sponsor for implementation of this feature request (https://support.zabbix.com/browse/ZBXNEXT-1119).
            But who is perfect?
