I've applied some macros to my hosts, ie {$ENVIRONMENT} value 'Production', and I would like to check for this in triggers as follows:
{ops-search-01.prod.buydomains.com:system.cpu.util[,iowait].last(#2)}>95 & {{$ENVIRONMENT}.regexp(Production)}>0
I get the error
Incorrect user macro "{{$ENVIRONMENT}}" format is used in expression.
I've tried various formats, but nothing seems to work. Can you use the regexp function on a User Macro? If so, how should I format it?
I get the error
