Severity help
  • trimkunas
    • Jun 2013
    Severity help
    Hello
    I need big help.
    I'm using zabbix 1.8.13 ver. And when confronted with a problem. I need more severity than those that have zabbix (not classified, Information, Warning, Average, High Disaster), perhaps there is a way to have or make another saverity?
  • jaba
    • Apr 2013
    • 11
    So far as I checked, there is no such feature. But you can probably open feature request in Zabbix bug-tracker about dynamic trigger severity.
    • trimkunas
      • Jun 2013
      I want that if the severity is high for example. Big load send mail for me, and if the problem ping send mail my colleague, but the severity also is high. How to do it?
      • jaba
        • Apr 2013
        • 11
        For that you probably need to take a look on:
        • trimkunas
          • Jun 2013
          But my zabbix version is 1.8.13.
          • trimkunas
            • Jun 2013
            https://www.zabbix.com/documentation...cations/action
            Thanks,
            problem resolved )
