Map question
  • Dum
    • Jun 2006
    Map question
    I want map to show ON/OFF icons depending on simplecheck icmpping item, or any other item. Is it possible?
  • achu_sab
    • May 2006
    • 49
    Yes its possible
    Create trigger with the icmpping for a host and in maps created a connection using "Link status indicator" . It will on and off according to the trigger value
    For using icmpping you have to install fping (yum install fping).
    • Dum
      • Jun 2006
      Thanks achu_sab, you give me the way. But ideally, I want to see greyed icons of servers and workstations if they are unreachable.
      • eaglei15
        • Jun 2006
        • 12
        Difrent icon for host up/down
        Icon (OFF) and
        Icon (ON)
        So you can choose an icon for any state of host
        • Dum
          • Jun 2006
          How can type of ICON (ON/OFF) be linked with some triger or host's item, icmpping for example?
          • achu_sab
            • May 2006
            • 49
            In map OFF icon shows the status while the trigger is not true(means if you create a trigger using icmpping.last(0)=0 {assume green for up status server and red for down status server} then you have to give green as an OFF icon and red as ON icon). This will show you green when the server is up and will show you red when the server is down. Create a link with another host using the trigger you created for the host
            • adam.vollrath
              • Apr 2006
              • 31
              I believe it "links" with all of that host's triggers. If any of its triggers fire, it changes the image.
              BTW, I would like to see functionality to only change the status image for triggers above a certain priority.
              • Dum
                • Jun 2006
                You are right! Thanks!
                • AlexWhite
                  • Jun 2006
                  • 31
                  Unless it is correct? In fact the trigger works when an inequality truly
