Should the JMX interface for a Zabbix Host point to the IP Address/Port of the Zabbix Java Gateway?
I recently created a JMX agent Item, and I currently have the Host's JMX interface pointing to the JMX IP Address/Port. I am not receiving any data for the item, and I assume that is because I do not yet have the Zabbix Java Gateway installed and configured. I just find it weird that I am not receiving any errors. The item is "green" - enabled and a green check box icon underneath the "Errors" column.
I am using Zabbix 2.0.8.
Thanks.
Thanks.
