Dns (bind) monitoring without agent
  • lutphi
    • Jun 2013
    • 9
    I have DNS server in my DC which is not under my administration. (I don't have credetials). So I cannot install zabbix agent. Is there a way to mınitor DNS service without agent.
    Note that I can only access UDP 53 of DNS server other ports are blocked by firewall.
  • harmonica
    • Jan 2009
    • 251
    I,
    net.tcp.service[tcp,{HOST.IP},53]
    • chojin
      • Jul 2011
      • 64
      In addition to the port check, you can create an external check script which invokes /usr/bin/host to check if a certain address is still resolving.
      For example
      /usr/bin/host -s -W 2 www.zabbix.com my.dns.server
      If it returns errorcode 0 www.zabbix.com resolves
      else it doesn't...
