Good Morning,
i´m using zabbix-server 2.0.9_rc1-r2. This is the stable release on gentoo. Since i upgraded from 2.0.8 i don´t have the init script under /etc/init.d. So i do not know how to start/stopp the server. There is no zabbix-server file for start/stop. I reemerged it several times but i do not get a init Script? Any Ideas?
find / -name zabbix-server /sys/fs/cgroup/openrc/zabbix-server /run/openrc/daemons/zabbix-server /run/openrc/started/zabbix-server /usr/portage/net-analyzer/zabbix/files/1.6.5/init.d/zabbix-server /usr/portage/net-analyzer/zabbix/files/2.2/init.d/zabbix-server /usr/portage/net-analyzer/zabbix/files/1.6.6/init.d/zabbix-server /usr/portage/net-analyzer/zabbix/files/1.4.6/init.d/zabbix-server /usr/portage/net-analyzer/zabbix/files/2.0/init.d/zabbix-server
[I] net-analyzer/zabbix
Available versions: 2.0.9_rc1-r2 ~2.0.9_rc1-r3 ~2.0.9 ~2.0.9-r1 **2.2.0-r4 {agent curl frontend iodbc ipv6 jabber java ldap libxml2 mysql odbc openipmi oracle postgres proxy server snmp sqlite ssh static ELIBC="FreeBSD"}
Installed versions: 2.0.9_rc1-r2(08:04:42 12/06/13)(ipv6 -agent -curl -frontend -iodbc -jabber -java -ldap -mysql -odbc -openipmi -oracle -postgres -proxy -server -snmp -sqlite -ssh -static ELIBC="-FreeBSD")
Homepage: http://www.zabbix.com/
Description: ZABBIX is software for monitoring of your applications, network and servers.
