Zabbix database growth too fast
  • jackyho
    • Nov 2017
    Hi All,
    Zabbix database size growth too fast. I'm using Zabbix version 3.4.2. Anyone know how to reduce it?
  • vesper1978
    • Nov 2016
    • 59
    Reduce the amount of items that you're monitoring, and/or reduce retention of the history and trends of those items you are monitoring.
    • troffasky
      • Jul 2008
      • 639
      or consider increasing the polling interval on items you do want to monitor.
      • tcilmo
        • Nov 2016
        • 122
        I echo what vesper said, reduce the amount of data collected (the items on hosts\triggers) and\or adjust retention polices (housekeeping). Administration > General > Housekeeping. Housekeeping for history and trends can be controlled in two ways. 1) globally or 2) or with the item config iteself. I personally would go with a global approach.
