Probem with TB value in items
  • cosmo223
    • May 2018
    I have simillar problem like in this topic
    When i have values which are bugger than 999 GB it should go to 1 TB but in my case it shows as a KGB.
    Does anyone had similar problem
    My zabbix version is 3.4.8
    Best regards,
    Matthew
  • Atsushi
    • Aug 2013
    • 2028
    Have you set the item units to GB?
    If so, Zabbix considers it to be a unit called GB.
    GB is not recognized as Giga Bytes.
    Please try to change the units of item to B(Bytes).
    • cosmo223
      • May 2018
      Yes this was a problem,
      My colleague was setting up template and use "GB" instead of "b"
      Thanks for clue
