Hello community,
I'm quite new to Zabbix and wanted to ask some questions about few components to better troubleshoot issues.
Here is my architecture (all on CentOS 7 virtual servers) :
- zabbix1 : zabbix "core" server (v3.2.4)
- zabbix2 : zabbix proxy
- zabbix3 : MySQL DB dedicated to zabbix proxy and zabbix server only
It manage I.T. stuff. I have about 450 hosts and 15k items (total including non-working/disabled ones). The fasters checks are for environmental data such as temperature and humidity, or pings (every 1min).
1) Zabbix config :
It seems I can config pollers, trappers, pingers, etc... on zabbix1 AND zabbix2. I only use zabbix2 as a proxy for all my hosts.
-----> Is it useful to start, let's say, 10 pollers on the server and 10 pollers on the proxy ? (5 pollers are not sufficient.)
I tried to disable all the pollers/trappers on the server, but it needed at least 1 trapper to receive data from the proxy if i understood.
2) Zabbix queue :
When I look to zabbix[queue] history (checked every 1min) it return different values than others displayed in the web UI "Queue overview" section.
For example, the last check show 5 items in the queue (and 0 in the "+10min queue") but in the overview i have 300+ items waiting for more than an hour.
zabbix[queue,1,60] seems to display different values as well.
-----> How can I get the same value displayed in the overview ? Is there another item like zabbix[queue] but more accurate ?
3) Zabbix performance monitoring :
I monitor Zabbix performance with Grafana. It works pretty well, but when i started a dedicated dashboard for Zabbix stats, i saw that "busy" graphs looked nearly the same for zabbix1 and zabbix2 servers.
Pollers, trappers, pingers, etc... are not of the same amount on each server. For example there is 1 poller started on zabbix1 (main server) and 15 on zabbix2 (proxy).
The first server is monitored by a "Zabbix server" dedicated template, and the second by a "Zabbix proxy" dedicated template which have few different items.
-----> In my case, is it useful to monitor the same items on zabbix1 and zabbix2 ? Can the little difference between values be caused by the latency between each check ?
I'm not sure if i'm clear enough on what i'm asking, so any explanation can be added if necessary.
Thanks in advance for your help!
1) Zabbix config :
2) Zabbix queue :
