Problem to convert a data Hex-string in Zabbix Item Value
  • Naillik
    • Jun 2018
    Hello, here is my problem "Item preprocessing step #1 failed: cannot convert value "" of type "string" from hexadecimal format: invalid value format"
    In fact, I use SNMP to get information on a printer : OID .1.3.6.1.2.1.25.3.5.1.2.1 and i get this normaly :
    1000 0000 0000 0000 : Low Paper
    0100 0000 0000 0000 : No Paper
    0010 0000 0000 0000 : Low Toner = 0020 Hex
    0001 0000 0000 0000 : No Toner
    0000 1000 0000 0000 : Door Open
    0000 0100 0000 0000 : Jammed
    0000 0010 0000 0000 : Offline
    0000 0001 0000 0000 : Service Requested
    0000 0000 1000 0000 : Input Tray Missing
    0000 0000 0100 0000 : Output Tray Missing
    0000 0000 0010 0000 : Marker Supply Missing
    0000 0000 0001 0000 : Output Near Full
    0000 0000 0000 1000 : Output Full
    0000 0000 0000 0100 : Input Tray Empty
    0000 0000 0000 0010 : Overdue Preventive Maintainance
    0000 0000 0000 0001 : Not assigned
    But when i catch the data it appears like that " " = 20 (ascii = Hex)
    ----------------------- New Test -----------------------
    Paessler SNMP Tester 5.2.3 Computername: INFO-0062 Interface: ZZZ.YY.Z.YY
    11/06/2018 15:27:49 (10 ms) : Device: ZZZ.YY.Z.YY
    11/06/2018 15:27:49 (14 ms) : SNMP V1
    11/06/2018 15:27:49 (18 ms) : Custom OID .1.3.6.1.2.1.25.3.5.1.2.1
    11/06/2018 15:27:49 (26 ms) : SNMP Datatype: ASN_OCTET_STR
    11/06/2018 15:27:49 (48 ms) : -------
    11/06/2018 15:27:49 (52 ms) : Value:
    11/06/2018 15:27:49 (57 ms) : Done
    11/06/2018 15:27:53 (9 ms) : Device: ZZZ.YY.Z.YY
    11/06/2018 15:27:53 (13 ms) : SNMP V1
    11/06/2018 15:27:53 (17 ms) : Custom OID .1.3.6.1.2.1.25.3.5.1.2.1
    11/06/2018 15:27:53 (23 ms) : SNMP Datatype: ASN_OCTET_STR
    11/06/2018 15:27:53 (28 ms) : -------
    11/06/2018 15:27:53 (33 ms) : Value: 20
    11/06/2018 15:27:53 (38 ms) : Done
    So zabbix don't want to get this value and i don't know how to convert it, in Hex or Bit
    And also use a trigger to easely get a report of the problem.
    Thanks for help.
  • kernbug
    • Feb 2013
    • 329
    According to https://support.zabbix.com/browse/ZBXNEXT-1888 try using DISPLAY-HINT defined for the corresponding MIB object.
    Or use external check for parsing hex string. Also find this https://support.zabbix.com/browse/ZBX-2452, but it is for old versions of Zabbix.
    • Naillik
      • Jun 2018
      Hi and Thanks
      Sorry if i'm misunderstand, (i'm new to zabbix and don't have a perfect english) but i don't understand how or where, i can change (in Zabbix, the item or administration) the Oa or DISPLAY-HINT defined for the corresponding MIB object.
      Or maybe will i use the Preprocessing steps to convert the value.I work on zabbix 3.4.9.
      Thanks for reply
      • kernbug
        • Feb 2013
        • 329
        Originally posted by Naillik
        Hi and Thanks
        Thanks for reply
        Here you can find working script to deal with parsing hex with whitespaces:
        Also there is an ability to choose data type HEX in item settings: https://www.zabbix.com/documentation...fig/items/item
        • keminc
          • Sep 2020
          Hello everyone, and thanks to people unsubscribed above ZBXNEXT-505. There is a little problem with 0x00 symbol in the SNMP, answer, so there is a little modified JS for converts HEX to String, for Zabbix data collectors prototypes and items.
          For discovery group:
          var regex = /"{#SNMPVALUE}":"([0-9 A-F ]*) "}/;
          var m;
          do{
          m = regex.exec(value);
          if (m) { var str = ''; hex = m[1];
          hex = hex.replace(/ /g,'');
          for (var n = 0; n < hex.length; n += 2) {
          if (hex.substr(n, 2) != '00'){ str += String.fromCharCode(parseInt(hex.substr(n, 2), 16)); }
          value = value.replace(m[1], str);
          } while (m);
          return (value);
          And for prototypes of items:
          var str1 = value;
          var hex = str1.toString();
          if (! hex.match(/\b[0-9A-F ]{6}\b/gi)) {
          return str1;
          } else {
          hex = hex.replace(/ /g,"");
          var str = '';
          for (var n = 0; n < hex.length; n += 2) { str += String.fromCharCode(parseInt(hex.substr(n, 2), 16)); }
          return str; }
