Zabbix 3.4 Web Scenario with XML String
  • lpossamai
    • Jun 2018
    • 119
    Hi all,
    I need to monitor an internal API that returns XML Strings.
    To run it with curl, I do the following:
    curl --cert /usr/share/zabbix/ssl/certs/cert_prod.pem --key /usr/share/zabbix/ssl/keys/key_prod.key -s https://api.example.com/Ping/1.1
    The output looks like:
    <?xml version="1.0" encoding="UTF-8"?><ping><service name="FBcheckOnline" status="down"/><service name="APICheckOn" status="up"/></ping>
    I would like to create a Web Monitor scenario that monitors a specific service. I want it to always checks if "APICheckOn" has a status="up". So then later on I can create triggers if a service goes down. How to do that using the Web Scenario tool? Creating a step and addting the required string to be like:
    ? Would that be enough? Thanks in advance.
  • kernbug
    • Feb 2013
    • 329
    Originally posted by lpossamai
    Hi all,
    Looks like "Yes" from the documentation https://www.zabbix.com/documentation...web_monitoring
